Hi there.
First post
I have recently started using a 32" Series 6 FHD Samsung smart TV as the display on my new PC - it is a few years old but firmware has just been updated.
The result is not bad.....from the distance I view it.
My issue is that when my PC goes to sleep, either on command or by setting time-out, the display continually shows a dialogue that says "No cable connected.......HDMI3.......check the cable......." etc.
Clearly the TV can't detect an HDMI connection when the PC is asleep.
When asleep, I want the display to be off with no message - particularly as this system is in the bedroom.
My question is: Has anyone come across and remedied this issue? Either through settings on the PC or TV? Or another solution?
Aside from a TV setting to power off after 2 or 4 hours after no signal, I can't find any way to stop the OSD showing when it doesn't detect a signal.
It is a right pain having to manually turn the screen on/off before/after use.
All help & direction greatly appreciated.
Cheers,
Audiocity99
First post
Cheers,
Audiocity99
