[SOLVED] Samsung SSD 840 EVO possible cause of system freeze?
zeekstern
30
My PC constantly freezes when playing games, when not doing anything, and whenever it feels like it. Some of the time I will hear a buzzing sound that lasts for maybe 15 seconds when it freezes. I put in a new power supply yesterday thinking that was it but it isn't. I have gotten a few BSODs but not many. A Win Defender Custom scan on the C drive freezes and never completes.
I built the system in 2014, so the SSD is over 7 yrs and I am thinking that is what is causing my issues. I ran a chkdsk /scan and it found no problems. It only took a few minutes which bothers me. I thought it would take a lot longer. A portion of the Samsung Magician Smart thing is:
Description Threshold Current Val Worst Value
Uncorrectable Error 0 100 100
Runtime Bad Count 10 100 100
Erase Fail 10 100 100
Program Fail 10 100 100
Used Resrved Blk Cnt 10 100 100
Do those results indicate a bad SSD?
My System Specs are:
CPU: 3.50 gigahertz Intel Core i7-4770K
Motherboard: ASUSTeK COMPUTER INC. MAXIMUS VI HERO Rev 1.xx
Ram: 16GB- 4 x 4096 MB
SSD/HDD:
Samsung SSD 840 EVO 120GB [Hard drive] (120.03 GB) -- drive 1, s/n S1D5NSBF251282H, rev EXT0DB6Q, SMART Status: Healthy
WDC WD1003FZEX-00K3CA0 [Hard drive] (1000.20 GB) -- drive 0, s/n WD-WCC6Y0USRF1P, rev 01.01A01, SMART Status: Healthy
WDC WD10EZEX-00BN5A0 [Hard drive] (1000.20 GB) -- drive 2, s/n WD-WCC3F2222144, rev 01.01A01,
GPU: NVIDIA GeForce RTX 2060 [Display adapter]
DELL S2721HGF [Monitor] (27.2"vis, s/n CMN9Z13, July 2020)
PSU: Corsair RM850x (BRAND NEW AS OF 8/8/2021)
Chassis: CoolMaster Cosmos ATX
OS: WIN10 VER 21H1 (OS Build 19043.1110)
Any and all help is appreciated!!
Zeek
A portion of the Samsung Magician Smart thing is:.......................Do those results indicate a bad SSD?
Those SMART values are perfect so there's nothing to worry about there.
The last freezing computer I tackled turned out to be caused by faulty RAM. Have you tested yours? There's a tester called "Windows Memory Diagnostic" built into Windows if don't have anything of your own.
