Hi forum,
I'm currently having a problem with one of my monitors, I use a two monitor and a TV setup and so I'm wondering whether the problem is with the monitor itself or with my computer? The monitor is old (~7 years) and previously had been working fine however now the monitor doesn't pick up signal very often. It started off showing the message not so often and unplugging and replugging the power cable would usually fix the problem once it started however now the message shows more often and plugging and replugging the power cable only fixes the problem occasionally. Is there anything else I should try or is the monitor faulty?
Thanks, Oliver
Thanks, Oliver
