I have a samsung sa350 syncmaster 24' monitor LED. Got it from the store used.
All it does when I plug it into my windows vista is flash HDMI, then analog, then shut off by itself. Itll immediately trun off if I press the change button. I installed the driver and firmware...same issue. Maybe graphics card but my other monitor (LCD) works fine.
I tried it on the windows 7 laptop...wont connect. Went to the setup screen for a second then went to check signal. crap.
Of course my macbook wont allow it because the driver isnt compatible.
Did I buy a hunk of crap?
Thnaks
Thnaks
