SanDisk X210 256 And 512 GB: Enthusiast Speed; OEM Reliability
Is the warranty 5 years or 3? Last page says one thing, an early page says another.Decent review, decent drives. Has THG considered doing something similar to what the car mags do, where they take certain products and use them for a year? It would be great to capture that kind of longer-term info on certain types of products, especially the kind that wear out (ODDs, fans, cases, HDDs, SSDs, etc.).
I agree with Chris. I don't need the fastest bench speeds in a SSD. Most models now are very fast and the user won't see the performance difference. I want reliability and longevity. Looks like this is a smart choice for any new builder.
Can we PLEASE have some normal graphs for once? The graph on page 5 in stupid 3D is so bad it's comical. The "perspective" effect completely screws with the data. This has zero added value and is almost as bad as still using clipart.
I find it hard to believe that the author has had "literally dozens of SSd's die" on him over the years. This would suggest that many systems have contributed to the demise of many of the SSD's being used, which seems somewhat outlandish. Just the cost factor involved in the purchase of so many SSD's and then having over a dozen of them fail, supposedly also from various companies, since if they were all from the same company it would not really be conducive to good sales. One, or maybe two I could live with, but dozens? No.
Agreed. Now it is truly screwed more than ever.
WTH is will the continuously scrolled unrelated articles, dropped newlines and just plain broken comments.
For the typical user that only has a few systems at the same time, yes. For someone who works with dozens of systems, the chance for one of them to fail goes up. Constantly building, testing, and reconfiguring machines means you're constantly imaging and re-imaging drives, which wears them out much faster than normal. Perhaps it was a little exaggerated, but it's definitely possible
Lol. All of the work that went into making page 5 seem like some super-complicated test. That is just HDTune, which can be ran with the click of a button and hardly requires and entire page and horrible graph for explanation.
There's actually a pretty huge difference between MLC-SLC translator based emulation and the way that tlc can behave electronically(physically) as SLC independently at the bottom of the translation layer. MLC-emulation has a partially positive and partially negative effect on translator stability, but with a robust controller(Marvell), the net effect on reliability is positive.With TLC as SLC, the effect is nearly perfectly proportionate to having SLC physically present.In fact, it is possible(with manufacturer tools) to take just about any TLC device like a 64GB usb flash drive and make it electronically indistinguishable(nearly) to a ~22Gb TLC flash drive in respect to performance, endurance, etc...MLC emulation is much more nuanced.
@Duff165. It's very believable that the author could have had dozens of SSD failures, especially if he used some brands like Mushkin. We were building systems using their 120GB SSDs and had nearly 75% failure rate within the first 6 months. Since then, we have used primarily Kingston with a few Intel and Crucial SSDs and haven't had a single failure since.
Since the major difference between the X210 and the Extreme II is the firmware, can you please test the Extreme II on the new DriveMaster TRIM test and see if they behave the same? SanDisk just turned into a new favorable option for me for my next drive.
Latest posts
