Hi all, I am trying to change out the MSI Geforce Video Card on my system with a new SAPPHIRE 100314-2SR Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
When I install the card and hook up the 2 6 pin power cables to the power supply, the computer will not boot. It boots and runs perfectly fine if I use my MSI Geoforce Video card in the system, but as soon as I take that out and install the Saphhire---there is no booting at all, infact all the fans quit spinning and no action at all on my monitors or computer.
here are the specs on my system:
Intel Core I 7 930 Processor 2.80 GHZ, 8mb L3 Cache, LGA 1366 Quad Core
Corsair Core i7 Dominator 12 GB PC12800 DDR3 RAM - Tri Channel, 1600MHz,
ASUS P6X58D Premium Motherboard - LGA 1366, Intel X58, SATA, SLI Ready, CrossFireX Ready, Triple Channel DDR3 support, RAID, Hyperthreading, USB 3.0, SATA 6Gb/s
I've RMA'd the card once already, just got the replacement card and it does the same thing. Incidentally the first card that I had was checked in another system, different motherboard and power supply, and it wouldn't run in that system either. That was on an Asus P6 motherboard, so wondering is this an incompatibility with Asus motherboards, or is there something else going on?
I did find some earlier threads on some other forums about other previous Saphhire cards which all in the same batch had similar problems, but nothing on the 6870 that would tell me if others are having this issue.
What else should I try before doing an RMA on this card? Thanks for the help.
Corsair CMPSU-1000HX 1000-Watt Power Supply - ATX, 140mm Fan, SATA-Ready, SLI Ready
