so, this is an old build, it's working nicely for quite a while. it's a sapphire rx580 nitro+
some time ago it begun making a very loud noise, after checking, one of the fans, the closest to the back is spinning at around 3K RPM, randomly, like, during boot, with 35°C temps, and also goes back to normal out of nowhere.
tried messing with wattman: if 0RPM is active, it shows me 0RPM constantly, if I turn it off, it shows the speed as it should, but no config, setting sound limit, custom curve or whatever, none let me reduce this spinning
tried afterburner: but it doesn't let me control fans
tried DDUing to see if it was driver, to no change.
any idea what could be happening and how to fix?
