Hi everyone,
First off, I would like to say that this is the first time I am overclocking my GPU which is a Sapphire 7970 that came with 950 Core / 1425 Memory Clocks + 1.2v.
I have been doing all the research I can over the internet about overclocking and I need your final advice to wrap my case up.
My first attempt was to install Sapphire Trixx which showed the voltage and what not. I tried to go with a 1100/1550 setup and it worked !. I spent 3 heaven benchmarks and got 70.4 fps - 1722 score - 69 C.
However everytime I tried to go up from 1100 core clock, heaven started to crash.
You see I am a complete fucking noob when it comes to voltage tempering therefore I installed MSI afterburner.
What I liked about MSI afterburner is that you can set up 20%+ and I managed to get a stable 1130 core - 1580 memory.
Now if I would like to go higher ( let's say aiming for 1200/1600)
a) should I use Sapphire Trixx and do what exactly with the voltage ?
b) should I change fan settings or leave it on auto ?
c) between trixx and msi, which one I should use or is there another program do you recommend
d) is there a secret formula to the ratio of Core to Memory speeds or is it more like ... you push core to the max before it fails ... you push memory before max it fails ... then you push the voltage and re-do the entire process ?
Please help and thank you 😀 <3
