[SOLVED] Sapphire Pulse RX 580 causes system power failure
GabeDG
9
I just recently purchased a Sapphire Pulse RX 580 8GB card.
I installed the card.
Connected the 8-pin adapater to power.
The computer posts properly.
Drivers were installed using DDU to remove the old software. Then, card settings were set to default using the Radeon Software.
The Radeon Software was set up to the default GAMING settings when asked Gaming/e-sports/Custom.
I believe the card itself is being underpowered, but, I do not know how to adjust the voltage safely to fix the issue.
Further, here's the system specs:
This is pulled from Speccy:
Summary
Operating System
Windows 10 Pro 64-bit
CPU
AMD Ryzen 5 1500X 42 °C
14nm Technology
RAM
16.0GB Single-Channel Unknown @ 1066MHz (15-15-15-36)
Motherboard
Micro-Star International Co. Ltd B350M PRO-VD PLUS (MS-7B38) (AM4) 44 °C
Graphics
HP Pavilion32 (2560x1440@60Hz)
L24q-20 (2560x1440@60Hz)
8192MB ATI Radeon RX 580 Series (Unknown) 47 °C
Storage
894GB Crucial CT960BX200SSD1 (SATA (SSD)) 35 °C
Optical Drives
No optical disk drives detected
Audio
Realtek High Definition Audio
Operating System
Computer type: Desktop
Installation Date: 10/12/2019 12:33:24 AM
Serial Number: RRQ8V-XHGTV-VVQY8-MKFRF-WFG6T
Windows Security Center
User Account Control (UAC) Enabled
Notify level 2 - Default
Windows Update
AutoUpdate Not configured
Windows Defender
Windows Defender Disabled
Firewall
Firewall Enabled
Display Name AVG Antivirus
Antivirus
Windows Defender
Antivirus Disabled
Virus Signature Database Up to date
AVG Antivirus
Antivirus Enabled
AVG Antivirus
Antivirus Enabled
.NET Frameworks installed
v4.8 Full
v4.8 Client
v3.5 SP1
v3.0 SP2
v2.0 SP2
Internet Explorer
Version 11.778.18362.0
PowerShell
Version 5.1.18362.1
Environment Variables
USERPROFILE C:\Users\wowat
SystemRoot C:\WINDOWS
User Variables
OneDrive C:\Users\wowat\OneDrive
OneDriveConsumer C:\Users\wowat\OneDrive
Path C:\Users\wowat\AppData\Local\Microsoft\WindowsApps
C:\Users\wowat\AppData\Local\Programs\Microsoft VS Code\bin
TEMP C:\Users\wowat\AppData\Local\Temp
TMP C:\Users\wowat\AppData\Local\Temp
Machine Variables
ComSpec C:\WINDOWS\system32\cmd.exe
DriverData C:\Windows\System32\Drivers\DriverData
NUMBER_OF_PROCESSORS 8
OS Windows_NT
Path C:\WINDOWS\system32
C:\WINDOWS
C:\WINDOWS\System32\Wbem
C:\WINDOWS\System32\WindowsPowerShell\v1.0\
C:\WINDOWS\System32\OpenSSH\
PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
PROCESSOR_ARCHITECTURE AMD64
PROCESSOR_IDENTIFIER AMD64 Family 23 Model 1 Stepping 1, AuthenticAMD
PROCESSOR_LEVEL 23
PROCESSOR_REVISION 0101
PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules
TEMP C:\WINDOWS\TEMP
TMP C:\WINDOWS\TEMP
USERNAME SYSTEM
windir C:\WINDOWS
Power Profile
Active power scheme High performance
Hibernation Enabled
Turn Off Monitor after: (On AC Power) 20 min
Turn Off Hard Disk after: (On AC Power) 20 min
Suspend after: (On AC Power) 240 min
Screen saver Disabled
Uptime
Current Session
Current Time 4/30/2020 8:38:14 AM
Current Uptime 35,730 sec (0 d, 09 h, 55 m, 30 s)
Last Boot Time 4/29/2020 10:42:44 PM
TimeZone
TimeZone GMT -8:00 Hours
Language English (United States)
Location United States
Format English (United States)
Currency $
Date Format M/d/yyyy
Time Format h🇲🇲ss tt
Scheduler
4/30/2020 8:51 AM; GoogleUpdateTaskMachineUA
4/30/2020 9:11 AM; DropboxUpdateTaskMachineUA
4/30/2020 9:50 AM; update-S-1-5-21-2027001316-939673837-3191400944-1001
4/30/2020 10:47 AM; update-sys
4/30/2020 2:51 PM; GoogleUpdateTaskMachineCore
4/30/2020 9:59 PM; klcp_update
4/30/2020 10:13 PM; StartCNBM
4/30/2020 10:22 PM; OneDrive Standalone Update Task-S-1-5-21-2027001316-939673837-3191400944-1001
5/1/2020 8:11 AM; DropboxUpdateTaskMachineCore
AMDLinkUpdate
CCleanerSkipUAC
ModifyLinkUpdate
StartCN
StartDVR
Hotfixes
Installed
4/30/2020 Advanced Micro Devices, Inc. - Display - 26.20.12028.2
Advanced Micro Devices, Inc. Display driver update released in
August 2019
4/30/2020 Advanced Micro Devices - MEDIA - 11/16/2017 12:00:00 AM - 10.0.1.6
Advanced Micro Devices MEDIA driver update released in November
2017
4/29/2020 Advanced Micro Devices, Inc. - Display - 26.20.12028.2
August 2019
4/29/2020 Advanced Micro Devices - MEDIA - 11/16/2017 12:00:00 AM - 10.0.1.6
2017
4/16/2020 2020-04 Cumulative Update for Windows 10 Version 1909 for x64-based Systems (KB4549951)
Install this update to resolve issues in Windows. For a complete
listing of the issues that are included in this update, see the
associated Microsoft Knowledge Base article for more information.
After you install this item, you may have to restart your computer.
3/14/2020 2020-02 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1903 for x64 (KB4537572)
3/14/2020 Feature update to Windows 10, version 1909
Install the latest update for Windows 10: Windows 10, version
1909.
3/14/2020 2020-03 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4551762)
3/12/2020 Windows Malicious Software Removal Tool x64 - March 2020 (KB890830)
After the download, this tool runs one time to check your computer
for infection by specific, prevalent malicious software (including
Blaster, Sasser, and Mydoom) and helps remove any infection that
is found. If an infection is found, the tool will display a status
report the next time that you start your computer. A new version
of the tool will be offered every month. If you want to manually
run the tool on your computer, you can download a copy from the
Microsoft Download Center, or you can run an online version from
microsoft.com. This tool is not a replacement for an antivirus
product. To help protect your computer, you should use an antivirus
product.
3/12/2020 2020-03 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4540673)
2/14/2020 Security Update for Windows 10 Version 1903 for x64-based Systems (KB4524244)
A security issue has been identified in a Microsoft software
product that could affect your system. You can help protect your
system by installing this update from Microsoft. For a complete
associated Microsoft Knowledge Base article. After you install
this update, you may have to restart your system.
2/13/2020 2020-02 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1903 for x64 (KB4534132)
2/13/2020 Windows Malicious Software Removal Tool x64 - February 2020 (KB890830)
product.
2/13/2020 2020-02 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4532693)
2/12/2020 2020-02 Security Update for Adobe Flash Player for Windows 10 Version 1903 for x64-based Systems (KB4537759)
1/16/2020 Windows Malicious Software Removal Tool x64 - January 2020 (KB890830)
product.
1/16/2020 2020-01 Cumulative Update for .NET Framework 3.5 and 4.8 for Windows 10 Version 1903 for x64 (KB4532938)
1/16/2020 2020-01 Cumulative Update for Windows 10 Version 1903 for x64-based Systems (KB4528760)
System Folders
Application Data C:\ProgramData
Cookies C:\Users\wowat\AppData\Local\Microsoft\Windows\INetCookies
Desktop C:\Users\wowat\Desktop
Documents C:\Users\Public\Documents
Fonts C:\WINDOWS\Fonts
Global Favorites C:\Users\wowat\Favorites
Internet History C:\Users\wowat\AppData\Local\Microsoft\Windows\History
Local Application Data C:\Users\wowat\AppData\Local
Music C:\Users\Public\Music
Path for burning CD C:\Users\wowat\AppData\Local\Microsoft\Windows\Burn\Burn
Physical Desktop C:\Users\wowat\Desktop
Pictures C:\Users\Public\Pictures
Program Files C:\Program Files
Public Desktop C:\Users\Public\Desktop
Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Templates C:\ProgramData\Microsoft\Windows\Templates
Temporary Internet Files C:\Users\wowat\AppData\Local\Microsoft\Windows\INetCache
User Favorites C:\Users\wowat\Favorites
Videos C:\Users\Public\Videos
Windows Directory C:\WINDOWS
Windows/System C:\WINDOWS\system32
CPU
AMD Ryzen 5 1500X
Cores 4
Threads 8
Name AMD Ryzen 5 1500X
Package Socket AM4 (1331)
Technology 14nm
Specification AMD Ryzen 5 1500X Quad-Core Processor
Family F
Extended Family 17
Model 1
Extended Model 1
Stepping 1
Revision ZP-B1
Instructions MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, AMD 64, NX, VMX, AES, AVX, AVX2, FMA3
Virtualization Supported, Enabled
Hyperthreading Supported, Enabled
Fan Speed 1009 RPM
Bus Speed 99.9 MHz
Average Temperature 42 °C
Caches
L1 Data Cache Size 4 x 32 KBytes
L1 Instructions Cache Size 4 x 64 KBytes
L2 Unified Cache Size 4 x 512 KBytes
L3 Unified Cache Size 2 x 8192 KBytes
Cores
Core 0
Core Speed 3597.9 MHz
Multiplier x 36.0
Bus Speed 99.9 MHz
Temperature 43 °C
Threads APIC ID: 0, 1
Core 1
Multiplier x 36.0
Bus Speed 99.9 MHz
Temperature 42 °C
Threads APIC ID: 2, 3
Core 2
Multiplier x 36.0
Bus Speed 99.9 MHz
Temperature 43 °C
Threads APIC ID: 8, 9
Core 3
Multiplier x 36.0
Bus Speed 99.9 MHz
Temperature 43 °C
Threads APIC ID: 10, 11
RAM
Memory slots
Total memory slots 2
Used memory slots 1
Free memory slots 1
Memory
Type Unknown
Size 16384 MBytes
Channels # Single
DRAM Frequency 1066.0 MHz
CAS# Latency (CL) 15 clocks
RAS# to CAS# Delay (tRCD) 15 clocks
RAS# Precharge (tRP) 15 clocks
Cycle Time (tRAS) 36 clocks
Bank Cycle Time (tRC) 51 clocks
Command Rate (CR) 2T
Physical Memory
Memory Usage 37 %
Total Physical 16 GB
Available Physical 10 GB
Total Virtual 20 GB
Available Virtual 10 GB
SPD
Number Of SPD Modules 1
Slot #1
Type Unknown
Size 16384 MBytes
Manufacturer Patriot Memory
Max Bandwidth DDR4-2132 (1066 MHz)
Part Number PSD416G21332
Timing table
JEDEC #1
Frequency 740.7 MHz
CAS# Latency 10.0
RAS# To CAS# 10
RAS# Precharge 10
tRAS 25
tRC 35
Voltage 1.200 V
JEDEC #2
Frequency 814.8 MHz
CAS# Latency 11.0
RAS# To CAS# 11
RAS# Precharge 11
tRAS 27
tRC 38
Voltage 1.200 V
JEDEC #3
Frequency 888.9 MHz
CAS# Latency 12.0
RAS# To CAS# 12
RAS# Precharge 12
tRAS 30
tRC 42
Voltage 1.200 V
JEDEC #4
Frequency 963.0 MHz
CAS# Latency 13.0
RAS# To CAS# 13
RAS# Precharge 13
tRAS 32
tRC 45
Voltage 1.200 V
JEDEC #5
Frequency 1037.0 MHz
CAS# Latency 14.0
RAS# To CAS# 14
RAS# Precharge 14
tRAS 35
tRC 49
Voltage 1.200 V
JEDEC #6
Frequency 1066.1 MHz
CAS# Latency 15.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
JEDEC #7
CAS# Latency 16.0
RAS# To CAS# 15
RAS# Precharge 15
tRAS 36
tRC 50
Voltage 1.200 V
Motherboard
Manufacturer Micro-Star International Co. Ltd
Model B350M PRO-VD PLUS (MS-7B38) (AM4)
Version 1.0
Chipset Vendor AMD
Chipset Model Ryzen SOC
Chipset Revision 00
Southbridge Vendor AMD
Southbridge Model B350
Southbridge Revision 51
System Temperature 44 °C
BIOS
Brand American Megatrends Inc.
Version 2.10
Date 8/1/2017
Voltage
CPU CORE 1.232 V
MEMORY CONTROLLER 1.040 V
AVCC 3.344 V
3VCC 3.424 V
VIN4 1.024 V
VIN5 0.184 V
VIN6 0.648 V
VIN7 0.000 V
VIN8 1.232 V
VIN9 0.608 V
VIN10 1.024 V
VIN11 1.040 V
VIN12 0.648 V
VIN13 0.808 V
VIN14 0.440 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x16
Slot Designation J6B2
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Designation J6B1
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Designation J6D1
Slot Number 2
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Designation J7B1
Slot Number 3
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Designation J8B4
Slot Number 4
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Data lanes x1
Slot Designation J8D1
Slot Number 5
Slot PCI
Slot Type PCI
Slot Usage In Use
Bus Width 32 bit
Slot Designation J8B3
Slot Number 6
Graphics
Monitor 1
Name HP Pavilion32 on Radeon RX 580 Series
Current Resolution 2048x1152 pixels
Work Resolution 2048x1112 pixels
State Disabled, Unsafe
Multiple displays Disabled
Monitor Width 2560
Monitor Height 1440
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Monitor 2
Name L24q-20 on Radeon RX 580 Series
State Enabled, Unsafe
Multiple displays Enabled
Monitor Width 2560
Monitor Height 1440
Device \\.\DISPLAY1\Monitor1
Manufacturer ATI
Model Radeon RX 580 Series
Device ID 1002-67DF
Revision E8
Subvendor Unknown (1DA2)
GPU Clock 1366.0 MHz
Temperature 47 °C
Core Voltage 0.750 V
Driver version 26.20.15029.27016
BIOS Version 113-4E353BU-O6B
Memory Type GDDR5
Memory 8192 MB
Bandwidth 256.0 GB/s
Power Supply is 750W
https://www.newegg.com/rosewill-rx750-s-b-continuous-750w-40c/p/N82E16817182067?Item=N82E16817182067
Well, while generally Thermaltake has issues, the Toughpower is mentioned as a good one. The 10 year warranty does make it clear that Thermaltake has faith in the Toughpower PSUs.
I wouldn't worry about crossfire, though - SLI and Crossfire are dying technologies, and few, if any, modern games support it. Still, extra headroom for a PSU never hurts.
EDIT: but once you install the Thermaltake, let us know if the problems go away. I'm PRETTY sure this is what it comes down to, but there's always that slight chance of something else being at issue. Even if that turns out to be the case, it's definitely better to have the new PSU.
I cleaned it up a bit more. But I need there to be enough technical specifications so people have a full accounting of my system's setup.
Thank you reading reviews on PSU looks like many people having faults with this brand of psu and on psu says Compatible with Core i7, i5 anyway hope people help you with this thread and good luck trying to get it to work but i think could be PSU yes its 750W but do not trust it with the reviews just read!
Rosewill's PSUs are mostly not that good. It's not necessarily about the wattage, but about the quality of the PSUs internals. That it has a 1 year parts/3 year labor warranty is concerning (and confusing, I don't think I've ever seen separate durations for parts vs labor on a power supply before), and tells me that the manufacturer has little faith in their product.
If possible, I'd try with a known high quality PSU, and see if you get better results. The first link in my sig has a writeup that gives recommendations and explanations.
Reactions: XxDarkMario20xX
I have had this power supply for 7 years with zero problems. Now, that being said...this could possibly explain the issues I was having with my R9 270X also...so it may be time to consider this part for replacement...but I DON'T WANNA...ughhhh.
I would really change that PSU if it 7 years even if you do not want to because one day that will fail and take your parts with it so could mean that PSU could be failing and would get new PSU to test it and known brand good one!
And after testing further, I have found a causation so far. So I play World of Warcraft and I don't normally tax settings to their max. But, to further test my GPU, I ran a dungeon with a 5-man group on 7 / 10 for graphics settings. Then, after getting out of said dungeon. I went into the graphics settings and turned it up to 10. Right as I applied the settings for 10 which enabled every graphics feature possible, the system shut down and reboot. I'm 99% certain it's a power supply.
Yeah, definitely power supply. And at that age, far beyond its warranty period, I'd look at getting a reputable one.
Take a look at the first link in my sig - the write-up in there offers a good analysis of PSUs to trust vs what to avoid. A good PSU will cost more (and it's even worse now with the tariffs and the pandemic), but it's a safety device. Safety in terms of providing your parts with clean, STABLE power, and safety in terms of, if something goes wrong, does the PSU
  • simply fail?
  • fail and take out other (expensive) parts with it?
  • catch fire?
The PSU is something you really want to be able to never have to think about once you install it.
Given your current specs, you don't need 750W. From one of the good models, even a 550W would be plenty.
  • simply fail?
  • catch fire?
I realize that the current setup doesn't require such a large power supply, but, I'm planning ahead if I decide to crossfire two cards together or add other hardware later that is more power intense. I'm giving myself room to grow.
I went with this. I realize that the link you recommended did not recommend Thermaltake power supplies, but, this one surprisingly has been reviewed very positive and the 10 year warranty is insane.
https://www.amazon.com/gp/product/B07SL9NFVS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Yeah I'll keep you updated as to how it's doing. Thanks for the advice!
Reactions: King_V
