Hi, i have problem when i run games on full screen. i get graphic crashes with my 7990 :
http://www.techpowerup.com/reviews/AMD/HD_7990/
http://imageshack.com/a/img921/8921/FR86kp.png
http://imageshack.com/a/img923/1020/ADiv7j.png
http://imageshack.com/a/img921/4751/Gd1el4.png
(Random red and black spot for a fraction of a second, flickering, etc. I don't have any problem in windowed or windowed full screen. My GPU2 temp is going crazy in full screen too, my pc even reboot sometimes. I was playing games in windowed for a while without any problems but now with Division, i run at 55 fps on low settings windowed and 55 fps on ultra settings while full screen, the fps drop in windowed is bothering me. I did a Benchmark Valley test :
API: DirectX11
Quality: Ultra
Stereo 3D: Disabled.
Monitors: Samsung T240
Anti-aliasing: x8
Full Screen: Yes
Resolution: 1980x1200
http://imageshack.com/a/img923/4505/fNpGd8.png
No graphic issue while testing but the temp went crazy on GPU2 which caused throttle.
My other hardware is not the problem, i tested my card in 2 different pc. 85 degrees flat on both GPU while gaming in windowed. I tried with the fans at 100%, same problem. its only the GPU 2 that causes all the problem. seems like a driver issue or something because GPU2 works fine in windowed with no graphic issue. Division, Rocket League, Overwatch, World of Warcraft and Tomb Raider are some of the games I tried full screen and had problems. I tried contacting MAD for support but no answer. Thanks guys, i hope someone will be able to help without telling me to buy a new card hehe =).
API: DirectX11
Quality: Ultra
Anti-aliasing: x8
Full Screen: Yes
