Recently I have had issues in Linux between a 780G/SB700 motherboard (Sata 2) and a tiny mSata disk (Transcend something 16GB) that while being extremely slow (14MB/s writes) should not really cause the system to hang for 2 minutes or more while IO was blocking to it.
The Linux kernel has a lot of IO queue issues that are not getting solved although they do try now a bit.
So I thought it would be just Linux. Now on another AM2+ motherboard with 785G chipset and Windows 10, and a Scorpio Black 2.5" 7200rpm Sata 3 drive, I experience the same kind of issues.
Call it "shit". Windows will hang for as much as 20-30 seconds while doing the simplest of tasks. You may press a button or click a field to input some text in a webbrowser, the webbrowser needs to read or write a few files, and the entire thing blocks for 20-30 seconds and you go out of your mind.
It is completely unacceptable and ruins everything. I mean there is much talk about SSDs but harddrives were never a problem to me before and now they are.
I have *never* in the past experienced issues such as this. From my first 80286 from IBM with 20MB harddisk to Windows 95 and XP with eventually maybe 10GB, to 160GB drives and 2.5" drives and one SpinPoint F1 of 660 (or 640, whatever) and even... well that's when the troubles began.
My recent 500GB ST500LM012 did not experience itself but in conjunction with the tiny mSata, it did. I have a bunch of 1TB ST1000LM024's and... no issue on a AM3 motherboard apparently (760G) and on this system too early to shout. Mainly at this point I am worried about that Scorpio and this AM2+ motherboard.
I have a AM2 motherboard soon with an even older Sata controller (likely) and I'm worried about these issues in Windows 10 predominantly.
Earlier I had a older laptop 2530p from HP with the stock 160GB hdd, and it experienced extreme slowdowns the likes of which you have never seen before: file transfers crawled down to below 500k/bs (effectively creeping to 0) when the rest of the system would still respond - a bit. Or games (Dosbox games) would cause the system to hang completely.
This was also in Windows 10. I prefer using Windows 10 if I do use Windows. 7 and 8 seem both of the last century or before. But thus far I have had almost nothing but performance issues.
Is there any reason this would be due to a Sata 3 drive running on Sata 2 motherboard?
Can it be due to missing drivers or ancient drivers in Windows 10 for the motherboard chipsets?
I would prefer more answers than "Yeah it might".
