[SOLVED] SATA power plug question
Jan 8, 2020
22
Hello, I have an old (from 2011) western digital blue caviar 500gb HDD pulled from a PC that recently died, and I intend to put it in a new model, but I'm concerned that the SATA socket on the drive won't be compatible with the new PSU. I've tried connecting this drive to a cooler master 500w, but the plug simply didn't fit when every source reassured that they're backward compatible.
What gives? Am I a ham handed idiot or is there a missing factor?
Sata data cable or power? Data cables haven't changed. Newer drives use sata power instead of the old molex type. If your psu has sata power connectors, a new drive should fit without issue.
Power. Here's an image of the connector I know fits for reference. it's an old-ish HDD made in 2011 that isn't compatible with a modern PSU.
On your Western Digital Blue 500GB you have 3 connectors. The one to the left is the SATA power connector. The one in the middle is the SATA Data cable and the one at the right is a PDATA molex connector. You plug any modern PSU SATA power cable in the SATA power connector to the left and it should fit or you can use a molex power connector to the PDATA. One or the other but not both at the same time.
SATA ports are L shaped on the side. You have a straight line and a small corner. Molex is just pins.
I see. But this raises a conundrum, I did try to connect it to a modern PSU with SATA connectors, but I swear to you, it didn't fit. Tried it both ways but it wouldn't smoothly slide all the way on.
