Save As settings will not hold
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Whever I need to right click something, a picture for instance, and
pick the save choice, the window that comes up is always configured as
"List" on the View Menu . I want "Detail" as the default, which is
exactly what I've chosen for my default folder configuration. I
change it to "Details" and the next time, it's right back to "List"
This is too annoying not to have a solution.
Thanks
When I right click a file I do not see a "Save" choice. You must have a
third party app installed that gives you this option. Do you recall what the
app is?
Harry Ohrn MS-MVP [Shell/User]
www.webtree.ca/windowsxp
"cuz202" <r274@mail.com> wrote in message
news:49leu01nno7hbo4cbdljfjebhgk6qiii5d@4ax.com...
> Thanks
This is not possible. These dialog boxes are not customizeable.
(tm)
On Fri, 14 Jan 2005 01:03:57 -0600, "Harry Ohrn" <harry---@webtree.ca>
>app is?
Harry,
Using Internet Explorer, right click on any link and one choice is
"Save target as". The dialogue box that comes up defaults (in View
Menu) to "List". I can change it to "Details", but the next time the
dialogue window is invoked, it's right back to "List". For people
with large numbers of folders and/or files in the left side choices
(Desktop, My Documents, etc), "List" is not a good choice.
Thanks
news:adagu01q9joo6q4n83876cjcsqpadsqjmu@4ax.com
>> have a third party app installed that gives you this option. Do you
>> recall what the app is?
> Harry,
> Thanks
That cannot be changed.
Frank Saunders, MS-MVP, IE/OE
Please respond in Newsgroup only. Do not send email
http://www.fjsmjs.com
Protect your PC
http://www.microsoft.com./athome/security/protect/default.aspx
