I'm looking for a SBC, thin client or other small, low wattage solution, which will run Windows 10 and Guitar Rig.
It doesn't need to be the latest Guitar Rig, I'm used to using GR5, and I'll be using a 2nd Gen Focusrite Scarlett 2i2, which should take up the slack in terms of a lot of the audio latency etc.
So it needs to be powerful enough to run Guitar Rig 5, either in Windows 10, or if it works well enough, through WINE in Linux, and it needs to provide enough power through USB to power the Scarlett 2i2.
Does Windows 10 run well enough on the Pi 4 to do this? If not, what's the cheapest x86 SBC that will handle Win 10 well enough?
Basically, I want something that I can keep hooked up to my Scarlett 2i2, that I can just plug my bass and headphones in to, fire it up, and it will load up Guitar Rig 5 and my saved presets without the need for a screen, then maybe manage it remotely from a phone or tablet with VNC if need be.
I've done this before with open source amp sim software on Raspbian on my Pi 3, but I want the same sound I get using my laptop.
Thanks!
Thanks!
