Scanner for 2.5 X 3.5 inch Negatives
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    Chip
G
Guest
Guest
Archived from groups: alt.comp.periphs.scanner,alt.comp.periphs.scanners,comp.periphs.scanners (More info?)
Hi
Can anyone please tell me if any of the popular (ie cheap) scanners
will handle 2.5 X 3.5 inch negatives without the need for a
separately purchased adapter?
If not, what is the cheapest way of tackling these - I have a few
hundred, so having these scanned professionally is not an option.
Brian Pears
Gateshead, UK
"Brian Pears" <bpears@freenet.co.uk> wrote in message
news:tmTBVNFVn0BCFwdt@tardis.main...
> Hi
> Brian Pears
> Gateshead, UK
Epson Perfection 4180 PHOTO will scan up to a 2.6" x 9" transparency
(negative and slide).
http://www.epson.co.uk/products/product_hub/Product_Listing_Scanners.htm
Epson 4180 Photo is 199 USD.
CSM1
http://www.carlmcmillan.com
Many thanks Carl, that seems ideal.
Brian Pears
Gateshead, UK
Brian Pears schrieb:
> Hi
It depends on what you want to do after you have scanned your
slides/negatives. If you want to get a scanner which is absolutely
phantastic for medium format, go for a Nikon Super Coolscan 8000ED. It
is less expensive to get than the new 9000ED. If you do not want or need
such a piece of equipment, go for an Epson 4870 - does this job very
well and costs less than half new compared to a second hand ED9000 on Ebay.
Rgds George
