Scared no idea what is happening Help
Kevin Deuel
39
I open File Explorer and all I see are magnifying glasses searching for my Hard Drives this Problem has come out of no where because and hour ago my computer was perfectly fine I have no installed anything new this is on Windows 8.1 + Update original not cracked. Here is an image to show what I see.
https://www.flickr.com/photos/121592946@N06/13912721000/
13912721000
That's a new one! Hope it's not a virus, a scan would be good...
Meanwhile check out your OS
First try System File Checker
Winkey plus 'X'
Choose Command Prompt (Admin)
Type sfc /scannow then Enter
It finds and fixes errors in Windows, but doesn't always report them. Run it and see if the fault disappears after re-booting your system
If corrupt files are found that can’t be fixed, try
Dism /Online /Cleanup-Image /RestoreHealth (Observe spaces before /)
Re-run SFC...
Don't see anything on your pic, but what you're describing sounds like the 'Bubbles' Screensaver...
Got desktop and Rt click on a space, choose Personalise then Screensaver and see what's selected,
No its not that, in file explorer the side bar only shows Favorites, Desktop, Homegroup and This PC and each of these has a small magnifying glass that moves around in a circular motion and does not find anything no HD, no Files no nothing
Winkey plus 'X'
Re-run SFC
To view CBS Log
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log >sfcdetails.txt
Search C drive for sfcdetails.txt or navigate to C:\Windows\System32 and scroll down.
