Scratch inside of laptop monitor?
fireblaster29
There appears to be some kind of small scratch in the inside of my laptop monitor, where I see a bit of red. I am a bit worried about it as I have not seen it before and noticed just now.
Picture of it : https://imgur.com/FyZfd9C
Someone please tell me it's not as bad as I think 🙁
Other than being quite annoying with it in the middle of the display, as long as the display is working fine otherwise, I wouldn't worry about it.
Yes, eventually it can get larger, or the whole display could go out, but that can happen to any laptop (mark or no mark). :) If it really bugs you, you can always replace the display.
