I ordered a new monitor and I'm trying to use the old monitor as a secondary (dual monitor)
Both are connected using DP however as soon as i connect either one of them both starts to flicker
It's like only the background and the taskbar that flickers while there is a loading pointer icon
at the same time the pc stutters and I'm unable to open programs and such
I tried to do a clean reinstall on my GPU drivers and it works while installing the drivers since the secondary monitors loses connection
But after the install the second monitor lights up and the flickering starts again
I tried disabling G-Sync on the primary monitor and no luck there (2nd monitor doesn't have G-Sync)
Not sure if it's a problem the way it's connected 1 DP Cable from each monitor to the graphics card (I have 3 DP slots on the graphics card)
I tried replugging and reconnecting to different slots with no luck.
Please help 🙁
Please help 🙁
