Screen Replacement Problem
whats-a-computer
19
Hello I was replacing my HP screen and once done the screen was not readable as the computer started up, but once the computer was done completely booting up, the screen was readable. At this point i was running vista. Then i decided to install windows 7 and since it was not readable when starting up i decided to plug in a monitor. Once it was completely installed and booted up the screen was not readable again 🙁.
(This is what it looks like
http://imgur.com/fJbdsu5
http://imgur.com/NUnmahP
http://imgur.com/W3llpr7
http://imgur.com/pZf1mZa
http://imgur.com/kduxFzG
http://imgur.com/g3xDw17)
is the screen defective or is there something wrong with my computer? Any suggestion helps
there are a bunch of numbers on the screens, which numbers need to match? all of them?
well here are the numbers on the original screen
LTN1543-L01
6W7GC0715I HOB
CT: C390402EE3UW8FP
Thats on a large sticker at the top
On a smaller sticker at the bottom
LJ96-02843B
LTN154X3-L01-0006
DD77269SQC29H3373
Any idea whichone it is?
