Hello,
Recently I purchased a 500gb M.2 SSD.
I opened my desktop case and removed the GPU in order to place the m.2 SSD.
I noticed a screw already placed in one of the three holes where I needed to put a screw, in order to tighten the M.2 SSD so it won't automatically jump back up. (Check the picture down below to see what I mean). It is a really tiny screw which I needed specific tiny tools for which I luckily have. So I head on and tried to gently unscrew the *already placed screw* but while doing so the bottom part of the screw broke off and is now stuck in the one and only hole where I can attach the M.2 SSD. I put the head of the screw in a bag just in case, but I wont be able to unscrew it like this.
I tried contacting MSI since I have a MSI Godlike Gaming X99A motherboard, they told me to contact the store from where I bought the motherboard and they simply tell me to contact the motherboard manufacturer. This will go on for ever.
How can I possibly fix this issue? I mean I can live without a M.2 SSD but would prefer to find a solution in order to fix this.
Here you can see where the bottom part of the screw stuck in one of the three holes.
Thanks in advance.
Thanks in advance.
