script error in help system
john
Splendid
Aug 25, 2003
3,819
Archived from groups: microsoft.public.win2000.file_system (More info?)
This is my second post on this problem. I have had some
help but my problem persists.
I am using win2K SP4 and get a script error when I access
some parts of the windows help system (from Start button)
The dialogue box is entitled ..."Internet Explorer Script
error" The contents of the box starts out by saying "An
error has occured in the script on this page" It goes on
to show other details, mainly numerical. I am using IE6
with latest SP etc. I have reinstalled Win2K and IE6 but
the error still happens.Anyone have any experience in
this? Much thanks
John,
> error"
1) Use MJ's Help Diagnostics to check that all the help viewer
components are properly installed and registered.
http://helpware.net/downloads/index.htm#MJs
(The only section of the MJ's Help Report that is relevant to your
problem is the one headed "HTML Help Run-time Components".)
2) Delete or rename the file hh.dat, which you should find in this
hidden directory:
\Documents and Settings\%username%\Application Data\Microsoft\HTML
Help
The hh.dat file stores user-specific information on all the HTML Help
files on your system (favourite topics, search history, etc.), and can
cause the files to misbehave if it has somehow been corrupted. Windows
will create a new version of hh.dat when you next open any .chm file.
3) Empty your Temporary Internet Files directory. A full TIF directory
can cause HTML Help files to misbehave.
If you continue to have problems, can you let me know the version
number of the file hhctrl.ocx, which you should find in the directory
\WINNT\System32?
Pete (Microsoft Help MVP)
Thanks Pete,
I tried your advise and it worked.
I cleaned the TIF directory and deleted the hh.dat file
also.
My help system is now working perfectly.
Your patience and expert help is much appreciated
Regards John
>-----Original Message-----
>John,
access
button)
Script
>> error"
viewer
relevant to your
Components".)
find in this
>hidden directory:
Data\Microsoft\HTML
>Help
the HTML Help
etc.), and can
corrupted. Windows
any .chm file.
TIF directory
version
the directory
>\WINNT\System32?
