heh. glutton for info aintcha?
The Typical bandwidth of a SCSI channel is ALOT larger than a ide drive.
the best ide can do is 133mb/sec and the standard SCSI is 160 or even 320.
of course, if you are using just one drive there is no way you will even use a tenth of 160mb/sec
i.e. my Pioneer 106S can do dvd's at 16x and cd's at 40x
so the max transfer rates we are looking at are
21Mb/sec for dvd, 6Mb/sec for cd copying.
thus while my dvd drive is actually ATA66, it will still run just as fast set to ata33.
of course u will get better burst transfer rates, but that really doesnt have much of an impact at all.
so the bandwidth advantages of scsi only exist for when u sport multiple drives.
and finally.
DMA = Direct Memory Access.
not sure exactly what happens, but i think with DMA enabled the drives and the IDE controller are allowed direct access to the memory independent of the Operating system... which makes the process alot faster and less resource hogging.
if u wanna see how much difference it makes, try disabling DMA on one of your drives!
win2k has a habbit of doing that at really strange times to me... and Non-DMA mode (PIO) is baaaaaaaaad. slow, and makes my athlon chuggy.
Morally destitute, Emotionally bankrupt but a proud and respected member of Toms Forums!
![Smile :smile: :smile:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
