Yet another fan controller with temperature sensors but no temperature control? I just can't understand this; if you have the hardware to adjust speeds manually and also to trigger alarms by temperature, then you have the hardware to adjust speeds by temperature, so why not give us the option to do that? Also, the ability to connect 4-pin fans to 3-pin headers isn't a feature; you can do that for any 3-pin header, and these days most 3-pin connectors are wide enough to fit 4-pin fans for this reason. The ability to actually control 4-pin fans via PWM would be a feature, but otherwise this just looks like yet another generic fan controller with no particularly useful features; a well designed case doesn't need more fans, it needs more intelligent control to get the most of out of fewer, properly chosen fans.
