Hello,
I got my problem with my SDHC Card (Samsung 32 GB). I formatted my SDHC in android as internal storage, I put it out, inserted it in SD Adapter and then in my PC. My pc is not reading it, but adapter and drivers are working fine. It will be readable only if I'm gonna format it via MiniTool Partition Wizard. When I'm in MiniTool Partition Wizard, its shows that its divided to 2 volumes. First volume is 16MB (created by android I think) and the other one is the rest of the sd card. If im gonna delete that 16MB volume or the rest, android will not recognize as the old one. The point I want to do with SD card is that I want to patriot it to 2 volumes which one will be Data and other one will be Apps. After that I want to work with Link2SD but I cant. When Im putting sd card back in the phone its says that its new sd card and not the old one. I didint copy original files earlier because It's not reading if its not formatted by MiniTool Partition Wizard.
Sorry for my english.
Any idea?
My info:
Samsung EVO Plus microSDHC UHS-I Card Class 10 32 GB
Samsung S4 Mini (GT-I9195) Rooted
CyanogenMod 13.0
CyanogenMod Recovery
Android 6.0.1
Any idea?
My info:
CyanogenMod 13.0
Android 6.0.1
