[SOLVED] Search Engine Hijacker
NatanTajak
Commendable
Mar 29, 2020
20
Hello everyone, I'll just cut right to it.
When opening Chrome or Microsoft edge, I keep getting redirected. Its still google, but the link above says its goal-nav.com or gosearch-uk first its goalnav when loading then it changes to gosearch. Not really a pc guy so I don't know how to get rid of it. Would really appreciate some step by step help.
look carefully at all startups, browser helper objects, and browser extensions, etc.; a freefixer scan displays all for careful deletion if you can't simply re-specify the desired homepage....
www.freefixer.com
Do you perhaps have a good restore point from before the browser hijack took hold?
