Hello, I recently purchased a used SeaSonic M12ii GM 520w BRONZE PSU from eBay for $27. It works great but I have an issue.
https://www.outletpc.com/jz4989-seasonic-m12ii-520-bronze-atx-psu.html
This PSU from the factory comes with a 6 pin and 6+2 pin modular cable, however, mine only came with the single 6 pin cable. I managed to get a partial refund of $10 because it was not listed as missing the 6+2 pin cable.
I am looking to find a way to power a 6+2 pin GTX960 with this PSU. I have a dual Molex to 6 pin adapter than a dual 6 pin to 8 pin adapter, but I'm not going to risk that.
I found the correct modular cable on eBay, but it will take months to ship, which I'm not waiting for.
I am struggling to find the correct cable anywhere else.
This PSU is not compatible with the modular cables from the newer SS M12ii 520w EVO PSU, as the EVO uses an 8 pin connector on the PSU side for the PCIe cables, where this older M12ii only uses a 6 pin on the PCIe side for the 6+2 pin connector.
I did notice however, this PSU has both a 4+4 pin and a solid 8 pin for CPU power. Given the CPU 8 pin supplies more power than a GPU 8 pin, could I use a CPU 8 pin to PCIe 6+2 pin adapter?
I'm not going to return the PSU since I won't be able to get nearly as good of a PSU for the $17 I have into this currently.
