I wont get into it,but I will say for mobo's I would only use
1)asus
2) gigabyte or asrock.
It is not a good idea to build an i7 gaming rig in the lowest B85 board available, the alternatives are cheap enough
(Asrock H97 anniversary is about $60). Also use ripjaw x 1866 cas 8, or 1600 cas 7 ram for an H97 build,if you can find the budget.
(they are the same quality~; the 1866 cas 8 will run at cas 7 at 1600 speeds, or near enough).
Source by current price.
