Question Seasonic PRIME ULTRA TITANIUM 850w and 2080 Ti - question.
litwicki23
576
Hello i bought new PSU:
https://www.x-kom.pl/p/399265-zasilacz-do-komputera-seasonic-prime-ultra-850w-80-plus-titanium.html
My card will be Aorus 2080 Ti Xtreme Waterforce.
But i have found topic with issue with that PSU and 2080 Ti:
https://forums.evga.com/EVGA-2080-Ti-XC-Ultra-tripping-OCP-on-Seasonic-PSU-m2908567.aspx
But i will be not have problems?
Somebody said:"I had very similar problems that you've experience using several Seasonic PRIME Titanium Ultra/non-Ultra 850W (1x new) 750W (3x - 2 new, 1 RMA) PSUs. When I game or GPU stress test (with a max power draw of 430-520W), the PC would randomly power off and reboot. This rarely happened at first but has happened more frequently over time. I had this happen to me when I had my 8700K+Z370+Titan V build, 9900K+Z370+2080 Ti build, 9900K+Z390+2080 Ti build while using various 750W and 850W Seasonic PRIME Titanium Ultra and non-Ultra PSUs. I've replaced nearly all components in my PC, PSU cables (Ensourced and OEM), surge protector, swapped power outlets around the house, and battery backup, but I still experienced random shut-offs. This week I've replaced the Seasonic PSU with an EVGA Supernova T2 850W. I have not had any random shutdowns under GPU load so far. I will report back if this changes but I highly recommend testing your system with another PSU as I suspect the Seasonic PRIME Titanium PSU degrades over time.
I'm not sure what....if anything.....is going on with the Seasonics....but I've been running a Founders Edition 2080 Ti for about a year with a Corsair RMx 1000 with zero issues.....so if you have concerns, I would recommend this....and you can probably get away with less than 1000.
