The Seasonic Connect power supply can help with keeping cable management tidy.
Seasonic's Connect PSU Is for Cable Management Nitpickers : Read more
I like this idea.
The connect hub itself doesn't look modular, but it should be. That way they could offer a range of sizes.
This is the first product. I imagine if it sells they'll begin tweaking the design so that it can fit into smaller cases and be produced in a wider rage of wattages.I am surprised the hub is so thick. I would think you could get away with something slightly thicker than the molex sockets. They could probably source some different sockets that would enable an even lower profile. The hub itself, like Giroro said could be modular. Allowing you to place sockets on a clip on rail system for ultra short runs and orthogonal cable layouts.
And you'll be the first to break it.I am surprised the hub is so thick. I would think you could get away with something slightly thicker than the molex sockets. They could probably source some different sockets that would enable an even lower profile. The hub itself, like Giroro said could be modular. Allowing you to place sockets on a clip on rail system for ultra short runs and orthogonal cable layouts.
The next evolution would be for the case manufacturer to include a power distribution board in the back of the case so that you only need 3-6" cable runs from the distro-board to the component. You could easily include a fan controller and some awesome art or an epic amount of RGB. The board alone if done in a large scale would probably only be $50 premium. A one-off would be...$250 maybe more.
Why would you say that? Without any context or a more specific quote it sounds like a unprovoked veiled ad hominem attack. Perhaps you'd like to clarify?And you'll be the first to break it.
