Sir U Mean U wanna Use The Intraged Graphic Card To Show The Second Monitor ? Well Here Is The Idea
Make sure you do install the intel HD graphics driver.
Since you have a graphics card it gets disabled. There is an option in bios to enable it if you want both enabled but there is no point since it won't be doing anything unless you want to use quicksync.
Try reboot the PC, boot into the BIOS in the graphics section to see you can set to onboard, or you can use both of them, or auto detect
Hope It Can Be Helpful To Solve The Problem
Sorry For Bad English
Best Regards And Good Luck
Khd
