[SOLVED] Second monitor not being detected correctly
Sep 7, 2021
My second monitor isn't being detected properly. It's plugged in but there's no signal to it at all.
It's from my old setup as I bought a new computer recently. It uses a DVI connection and I bought a DVI to HDMI cable to be able to use it with my new PC as there's no DVI port on the 3080Ti.
I've returned the cable and exchanged it for another one thinking the cable was faulty but I'm getting the same problem with the new one.
The cable doesn't work in either my new PC or old one. But the monitor works fine with my old PC with the original DVI cable.
It's a QNIX qx2710 if that makes any difference.
It shows up in the Nvidia Control Panel, but I'm unable to tick the box next to it.
View: https://i.imgur.com/KBVqfIE.png
Shows up in Windows Display settings also but not properly.
View: https://i.imgur.com/NMoeH0j.png
And it's showing under device manager but not properly also.
View: https://i.imgur.com/i9nNpHl.png
