Question Second Monitor Not Detected
manny_gabby
14
I'm trying to add a second monitor but Windows 10 says it can't detect it.
Windows 10
AMD Radeon RX 5700 XT
Just looking for any guidance.
Thanks.
Windows 10
Thanks.
What is the specific error message? Post a screen capture (Upload to Imgur.com and post the link here). Though the most likely reason the monitor doesn't work is that you didn't enable it in display settings.
Reactions: Lutfij
"Panels" is another name for monitor. They have an LCD or oLED panel as the means of disply.
To put it another way, what are the make and model of the two monitors you are trying to connect to your RX5700?
The main one that is working fine is a Sony tv. The second one that isn't being detected is a Samsung TV Model UN32J400DAF.
Latest posts
