Hi All -
Just finished my first homebuilt (config below,) and I'm very pleased with it.
Before I close the case, I'm looking for advice on how best to secure those small fan wires.
In particular, I'm looking at the wires coming off the heat sink fan and the case fans (back and top.)
The heat sink fan has already "eaten" its own wires once. There was no damage, and since I have the case open it was easy to untangle. However, once I close, I really don't want to have to open to unwind a wire from a fan.
I think I can pull the case fan wires straight down into the wire management side-panel space, but there doesn't seem to be any obvious ways to secure the heat sink fan wires.
Also, should I be concerned about either vibration or direct heat wearing away the insulation of these smaller fan wires if they are touching any of the components? I'm looking at the heat sink fan wires resting against the fins of the CPU heat sink itself and the passive heatsink for the onboard MOBO components.
Configuration:
Core i7-920
- Standard Intel heat sink that comes with the CPU
Asus P6T Deluxe v2
EVGA GTX275
WD Black Caviar 1TB
3x2GB DDR3 OCZ RAM
Corsair 1000W PSU
Antec 902 Case
Many Thanks,
GorfTheFrog
Configuration:
Core i7-920
Asus P6T Deluxe v2
EVGA GTX275
WD Black Caviar 1TB
3x2GB DDR3 OCZ RAM
Corsair 1000W PSU
Antec 902 Case
Many Thanks,
GorfTheFrog
