Security key # for belkin wireless
colonelsc
OK I have a Belkin wireless unit what kind of # am I looking for ? There are a lot of numbers on it so which one do I need ? I'm looking for my security number for my wireless. thank you so much Lt. Colonel G. Rinchich
The security key for wireless access to the network through your router is not printed on the router. The security password is created when you set up your wireless encryption. So if you are the administrator of the network and forgot your password you must log into the router and change the password. You will have to hard wire a computer to the router in order to log into the router.
Is it the model with that one click connect button on it?
Either ways you need to connect to the LAN port on the router open the browser window and type the IP in the address bar, for eg. 192.168.1.1
You'll get a status page of the router and will see a login link on the right hand upper corner of the page.
Click on it, and you'll get the login window, use the default admin and password, usually admin/admin and log into the router.
Go to the wireless network on the left of the page got to the security and encryption page. Select WEP+WPA2 and give a new pass phrase for the network. You can also choose the name for the network in the Wireless Network Section.
Save and apply, the router will reboot in a minute.
And ..... you're on Air.....:)
Anyways, if you have anymore doubts , the router has a CD or a manual with it for the basic setup. It's pretty simple to trouble shoot.
I have just given you the basic outline of what you need to do with the whole thing.
You're welcome to ask if you get stuck further on, but, it's good to know the model of the equipment you're using to be able to help you out more precisely.
