It's from os, I also found that the system is finding an error on my c drive, but manually checking through cmd shows no errors.that message is from os or for hdd if it from latest one have it check in another system as secondary drive with is maker software .
I tried using a ssd repair app: AOMEI Partition Assistant, and file scan/repair shows no errors. Is it possible it's a false error?then i would do a file repair for os you could have a bad boot sector or error .
I didn't install the SSD in my PC, can you link me to a tutorial for repairing it in this way?do it with the os support you use to install it to repair your files that is the best way .
Thank you for the reminder.@Teneuom
Will add a quick suggestion:
Do remember to backup all data before doing anything else.
At least twice to different locations.
Verify that the backups are both recoverable and readable.
