7-14700K R$2899.99 i7-14700F R$2689.99An integrated GPU can be useful for troubleshooting.
For instance, if you suspect the dedicated GPU is failing.
In your market, what is the price difference between F and Not-F.
$42.73 price difference
Yes, even in my own language, AI makes corrections and improvements to the text, enhancing understanding and avoiding glaring errors. I speak English, so I don't have issues using the forum, but I'm not fluent, so I rely on AI. However, I might be biased to say that, as I use AI for almost everything nowadays, lol.K is unlocked, so it CAN be overclocked but it doesn't have to be. It is a useful option to have. Anyone not interested in overclocking should not immediately accept advice not to buy K intels. People can change their minds. More easily than CPUs.
F intels have no intergrated graphics. Buying F CPUs is not wise at all. The cost saving is minimal. Even if you'd never want to use integrated graphics, you'd always have the ability. GPUs can fail, or can have defects and need replacing. When the GPU is dead or dying, you can use the integrated graphics to test the machine in UEFI/BIOS, and you can boot the OS and actualy use the PC.
Without a graphics chip you have no monitor display and your PC is a power hungry heavy brick. For a small price increase, an integrated chip guarantees you will always be able to use the PC as long as the CPU is still alive.
Only a fool would save pennies buying an F intel.
Also, OP's posts read like AI generated replies. Amusing. Probably the translate.
