Build Advice Seeking advice on Desktop PC build
satimis_06
177
9
18,585
Hi all,
I'm preparing to build a Dual-Boot desktop PC with following component configuration:-
1)
CPU ***
AMD Ryzen 7 5800X Processor 8C 16T 36M Cache, up to 4.7GHz, Socket AM4
Cooling fan
Super quiet: Dark Rock Pro 4 TR4
https://www.windowscentral.com/best-cpu-coolers-amd-ryzen-7-5800x
2)
Motherboard *** (I don't need WiFi)
ASUS X570: ASUS Prime X570-P
PRIME X570-P Spec
Code:
4 x DIMM, Max. 128GB, DDR4 5100(O.C)/4800(O.C.)/4600(O.C)/4400(O.C)/4266(O.C.)/4133(O.C.)/4000(O.C.)/3866(O.C.)/3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3200(O.C.)/3000(O.C.)/2933/2800/2666/2400/2133 MHz Un-buffered Memory
Dual Channel Memory Architecture
1 x M.2 Socket 3 with M Key, type 2242/2260/2280 storage devices support (SATA mode & X4 PCIE mode)
1 x M.2 Socket 3 with M Key, type 2242/2260/2280/22110 storage devices support (SATA mode & X4 PCIE mode)
Dual 64Gb/s M.2  Diagram
https://www.asus.com/hk/Motherboards-Components/Motherboards/PRIME/PRIME-X570-P/
3)
SSD ***
3a)
ADATA 2TB XPG GAMMIX S70 BLADE AGAMMIXS70B-2T-CS M.2 2280 PCIe Gen4x4 NVMe SSD
for running Ubuntu 20.04/22.04 (Linux) and virtualization (Oracle VirtualBox)
3b)
ADATA 1TB XPG LEGEND 840 PCIe Gen4 x4 M.2 2280 SSD
for running Windows11 64bit
4)
RAM ***
Corsair 64GB Kit CMK64GX4M2D3600C18 Vengeance LPX DDR4 3600MHz (2x32GB)
5)
Graphic card
4K display card - already available, brand-new
GeForce GTX 1650 SUPER™ GAMING X
MSI Twin Forzr 7 MS-V385
https://www.msi.com/Graphics-Card/GeForce-GTX-1650-SUPER-GAMING-X/Specification
6)
Hard drive for data storage ONLY- already available
WD 4TB HDD SATA3 (Format - ext4)
7)
Power supply - already available, brand-new
Corsair CX550M
1) Please advice whether the abovementioned configuration workable ?
2) If upgrade to AMD Ryzen 9 5900X (motherboard unchanged), would there is any recognised improvement in operation ?
Thanks in advance.
Regards
Thanks for your advice
I'll purchase;
Corsair CX650 — 650 Watt 80 PLUS® Bronze Certified ATX PSU
https://www.corsair.com/us/en/Categ...Supply-Units/cx-series-config/p/CP-9020122-NA
The new dual-boot desktop PC;
1)
36 cloned wordpress sites are running on VMs of Oracle VirtualBox. In case of any live site having problem I can clone the local site to the server of the hosting company to replace the problematic site.
2)
For Video and graphics editing
Regards
