Seeking subwoofer replacement.
edzilla
24
Any ideas? I'm using a GX pc multimedia setup but my subwoofer got "yanked" from my amp and the cord broke. Was just looking to replace the sub only since the other two speakers and amp seem to be working fine. Though.. I am having trouble finding a website that does that? I really could care less if it's the same brand, It just has to be a sub with the same connection (RCA cables) since that is what my amp uses. I'd like something with good bass, but besides that I have no preference! Well, that and something on the cheaper end 😛
Thanks!
To tell you honestly, it will probably cost you more (especially considering shipping costs) than that system is worth if you were to try to replace the sub. It's a 5.25" passive sub of relatively low quality, and you'd probably find it cheaper to buy a new or used 2.1 speaker system (Logitech or Creative give you decent bang for the buck). Repairing the damage would have been your cheapest option.
Sorry, they're specifically Genius SW-G2.1 1250 Gaming Speakers. The tong that connects the RCA cable to the amp broke off (the middle metal piece on the head? not sure what it's called) I already trashed the speaker anyway, so im not really wanting to "fix" it if thats what you're getting at.
Don't really have any areas around me that sell just subs - anywhere i can purchase this online?
