G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
This should bring back memories to the older members reading this post.
I just found additional printer options when updating from Qicken'98 on
Win98 to Qicken'03 on WinXP. I've been using an Apple ImageWriter-II
Impact printer to print tractor feed checks for years by bypassing the
printer driver. It has proved reliable and economical; I print over
1000 checks a year. However, I'd like to be able to use this printer's
printer driver option, so I can get a more legible font.
With the C-Itoh driver, I get nicely formed characters properly spaced,
however, the space between checks is wrong. Quicken in CHECK PRINTER
SET UP / SETTINGS / PAPER / ADVANCE / SIZE enables only setting the
check printer paper size to "letter", "A4", or "250 x 340mm. There is
no option to set the paper height to 3.667 inches, the height of the
preprinted tractor feed checks.
Is there a way I can send printer commands such as <esc>r (reverse
direction of feed) to the printer either before or after each check is
printed, so as to in effect reduce the page size? Or perhaps, is there
a way to insert a custom printer driver to send the proper font and page
feed commands?
feed commands?
