My USB is a 2TB Kingston DataTraveler 200 it was working for a while but then it stopped and I'm not sure what I did. I don't think its in read-only mode but i dont know how to tell (theres no switch on the usb that can
toggle it)
So I'm gonna try to list what i noticed whats wrong with the usb:
when i plug in the usb it says you need to format the disk in drive F: before you can use it, do you want to format it? so i clicked format disk it shows
Capacity: it has a drop down bar with the only option being 8.00 MB
File system: with a drop down bar that has 3 different options
NTFS, FAT (Default), and exFAT.
Allocation unit size: has another drop down bar the options
64 kilobytes, 32 kilobytes, 16 kilobytes, 8192 bytes, 4096 bytes, 2048 bytes and Default allocation size
a button that says Restore device defaults
a text box titled Volume label (which i dont know what it is and it has nothing in it anyways)
Format options with 2 check boxes: quick format and one that isn't selectable that says Create an MS-DOS startup disk
There is also a loading bar that doesnt do anything because whenever i click the start button under it, it says
WARNING: Formatting will erase ALL data on this disk To format the disk, click OK. To quit, click CANCEL
so i click ok and then it says Windows was unable to complete the format
then i click ok again and tried every possible combination of settings
and it still said the same thing so then i clicked cancel and it said
Windows can't format F
Check to see that the disk and drive are connected properly make sure that the disk is not read-only, and then try again. For more information, search Help for read-only files and how to change them. again I'm not too sure if my usb is write protected or not and I dont know how to check
when I open the properties of Removable Disk F: (which is my USB)
the general tab says this:
Type: removable disk
File system: (nothing)
Used space: 0 bytes 0 bytes
Free space: 0 bytes 0 bytes
Capacity: 0 bytes 0 bytes
(and a fully blue colored pie chart with the word Drive F: underneath)
I can't format the usb Here is a list of applications i tried:
hp usb disk storage format tool
Macrorit Disk Partition Expert
BootIce
JetFlash OnLine Recovery
UsbFix (which i think got me a virus not too sure)
Microsoft Fixit
They all said it was unable to complete the format or there was some error
Heres a list of stuff I tried without an application
restarting computer
refreshing my computer (as a 2nd to last resort but with this being my last, LAST resort but i lost all my files and now i am sad)
doing a scan with advanced system care (pro version)
using the command prompt to format it
using safemode command prompt to format it
switching usb ports
read a bunch of forum posts that didn't help.
well thats all i really have to say about this but just so you know the usb was working for a couple days, and im sure i have tried everything any normal person would do so if anyone would be kind enough to help me out please try to tell me some options that are not obvious thanks.
toggle it)
BootIce
Microsoft Fixit
restarting computer
switching usb ports
