Setting correct ram speed and timing
Prominia
28
Im new to overclocking, I recently overclocked my cpu where it is stable, but by doing, it lowered my ram to 1444mhz because i changed the SPD to 8 to reach my stable cpu overclocked.
When nothing is overclocked and i enable xmp it does read correctly..
My Ram is corsair xms3 rated at 1600 8-8-8-24 @ 1.65
CPU-Z shows it at 1444 mhz and 8-8-8-20. I do not want to overclock my ram i just want it to be stock at 1600.
I did read the manual for my mobo which is ga-x58a-ud3r, which it did say to enable the xmp profile to get correct ram speeds.
So all i really want to know is how to put my ram at 1600.
your ram should be able to do 1600mhz if its 1600mhz ram
its just the motherboard classes it as overclocking it--my x58 board also says it doesnt officially support 1600mhz ram except by overclocking
if you tell us what cpu speed you have overclocked to or want to overclock to it would be easier to explain
ie if you want 3.2ghz with 1600mhz on the ram
you set fsb to 160 and cpu multiplier to 20 then you set the ram multiplier to 10
160 x 20 gives cpu speed of 3200mhz and 160 x 10 ram multiplier gives you 1600mhz ram
just been mucking about on my second pc with x58 board and i7 920 to check
far as i remember x58 overclocking you may not get 1600mhz on the ram
as its the fsb x the multiplier
ie--if your ram is showing 1444mhz chances are your fsb is 180mhz so putting the ram multiplier up to 10 would make
your ram 1800mhz which it probably wont run at
my second pc has x58 with an i7 920
to get 1600mhz on the ram i used 20 x 200 for 4ghz and 8 x 200mhz for 1600mhz ram far as i remember
but you need good cooling for 4ghz
so what cpu do you have and what speed is your cpu running at?
Well CPU-Z is showing it at around 720ish, which would be 1444mhz. In the bios it also says 1444. I will post a screenshot when i get home.
I am stable at 3.78ghz with temps on full load around 67. I was playing around with some of the numbers, and i could get to 3.8ghz with 19x200, with the ram being exactly 1600. I will try this tonight and run prime and post the results. I am a little confused though between the cpu multiplier and the blck frequency, as if lowering the cpu multiplier and raising the blck frequency changes anything. I will post tomorrow the results.
I could also try 20x190=1520.
All these the spd would be at 8.
I appreciate your reply.
theres a few ways to tweak about with it
havent done it for a while on x58
but seem to remember being able to get my ram up to about 1680mhz as well as overclocking the cpu heavily
cant remember where the bclk limit was but it should go over 200mhz--might have hit the limit about 210mhz x 19
I ran it at 19x200 which gave me 3.8ghz and 1600 mhz on prime95 for 10 hours with 0 errors or warning so i am all good now. Cpu-Z is showing all of the correct timings as well.
Thank you for all of the help
