[SOLVED] Setting up a Geforce RTX 2070
Jul 21, 2021
6
Hi,
I have the PRIME H310M-A R2.0 Board from ASUSTek (official page). I recently bought a GeForce RTX 2070 grafics card (chip manufacturer is NVIDIA) (im1, im2). The card has two slots for power cables, one with 6 and one with 8 pins (im). My board only has one free connector that fits (front, back, pins, 6 pins as you can see, 3 black and 3 yellow cables.)
When I tried to make the card work, the initial result was that the monitor it was plugged into stayed completely dark. Eventually, I read that you have to change BIOS settings to enable the discrete card as the board also has two slots on-board for monitors. (I've had a two monitor setup for a while using those, which works well.) Since then, I instead get the message "Power down and connect the PCI cables for this video card,", same as the person here. I can't access the BIOS when this appears; however, once I unplug the card, I can boot normally again. The message does not change if I unplug the PCI-E cable.
Other than the 6-slot PCI cable, the only other free power cables I've found on the board are these two, which I don't imagine are useful.
So, what should I do? Do I need an 8-slot cable? A different 6-slot? Both a 6 and an 8-slot? Is there any way to make this work without buying a different board or card?
I don't know much about hardware, as is probably apparent from this description, so let me know if you need other information.
You need to purchase a new power supply.
Here is the PSU tier list.
here's a good article.
in general...Corsair and Seasonic are good brands....and I'd go with 650 watts or more (as I like a little overhead) but you can probably get a way with 550.
https://www.tomshardware.com/reviews/best-psus,4229.html
The graphics card needs both the 6 and 8 pin plugged in to work. 90% of power supplies today will come with a 6+2 pin on the cable, you will be able to use the 6 pin (tucking the 2 pins off to the side) for the 6 pin connector on the card. Then use another cable from the PSU that is a 8 pin ( not a cpu/esp cable) or another 6+2 to feed the 8 pin connector on the card
Alright, thanks the quick response.
What confuses me a bit is that, if I look for power supplies on amazon, the article descriptions don't include a list of cables. Do I just assume that a modern power supply is going to have all of the cables that I need (and is compatible with the board?) Or do I take the model ID and get the information from somewhere else?
For example, I was just looking at this one (apologies for linking to a german page but shipping) based on Watt and manufacturer. (EDIT: If I go by the recommendations linked here, then this would be it instead.)
Don't know except that it was a XILENCE. I'll probably know once I remove it.
When I bought this PC, I was specifically looking for an offer that didn't include any GPU -- figured that, since I don't care about graphics, I wouldn't need one, so let's save some money there. Probably this selected for a PSU with poor support for GPUs.
What I didn't know at the time is that GPUs are basically required to do serious machine learning.
Not only does the PSU work, it worked on the first try after I set everything up and booted the PC (including the graphic card). Given how unskilled I am with everything related to hardware, I'd say that's at least a medium-sized miracle.
Thanks a lot for the help. I would have never guessed that the Power Supply was the issue. I didn't even really know that it was a component you can swap out.
Old PSU: [1]
Trivia: I had to cut through the CPU cable on the old PSU to get it out of the case. The alternative would have been to remove a part of the case itself, and well screw that.
