I finally got off of Xfinity Internet to switch to AT&T Gigabit Fiber. As a result, I also "cut the cord" and went full Internet streaming of TV throughout my house. I recently saw on Youtube that you can use a "Coax to Ethernet" MOCA adapter to expand the reach of your Home network via your existing Coax Cabling within the house.
In one of the Corner rooms in the farthest corner of my house, there is an unused but connected Coax cable that runs out of the wall that runs to the main splitter that is located on the outside of my house. In my computer room where my main WiFi Router and AT&T Gigabit fiber is located, I also have the old coax cable frunning from there to the main splitter.
Since the Coax cabling in my house is now unused between the Computer Room to the Corner Room, am I able to connect the Coax Cables from both the rooms and use a "Coax to Ethernet" MOCA Adapter to effectively run a hardwired connection between the Computer room to the other Corner room?
Based off of the way I understand how this would work, I am thinking like this to connect everything together:
Main Router --> Ethernet Cable --> MOCA Adapter ( 1 ) --> Computer Rm Coax Cable --> Coax Connector --> Corner Rm Coax Cable --> MOCA Adapter ( 2 ) --> Ethernet Cable --> Second Router
When I read more into the COAX to Ethernet MOCA Adapters, it mentions something about utilizing higher frequency channels ( between 1125 to 1600 MHz ).
Since I'm not running any existing TV signals through the Coax Cable, am I able to use just a "regular" Coax connector to connect both Coax Cables?
or
Do I have to have one of those special Coax connectors that are designed to handle a MOCA data connection and/or higher frequency channels?
I'm trying to figure out if I need to get any type of special connectors that can handle and use the higher frequency channes or if I can just use a regular connector that I have at home.
In regards to the total length of the Coax Cable that I will have connected together, I have no idea how long the Coax Cable connection will be from one room to another. I don't think that there is any other splitters beyond the one mentioned above. My house isn't super huge, but is there any concern for Signal degradation that could impact the speed of the connection?
Any recommendation for any "Coax to Ethernet" MOCA Adapters that you have used?
Thanks for your response in advance.
or
