First I have to say that I'm not knowledgeable on networking, so I might be making some really basic error here. But I've tried and tried and read every post and still I am stuck so hopefully someone here can help.
I have an Etisalat D Link DIR850L router which connect to my broadband provider without any problem. I recently bought an ASUS RT-AC68U to replace it because I want to be able to run a VPN.
After lots of faffing around (I had to get the VLAN ID from Etisalat who didnt want to give it out) I was able to get the new router working. Great! However, my wife uses YouTube a lot so wants to bypass the VPN so it is faster. For that reason I am trying to use both wireless routers. Router 1 (the D-Link) would run normally so she could access it via wifi for youtube etc. Router 2 (the Asus) would sit behind it and I could then run the VPN on that.
So far is this making sense?
What I did:
Connected the broadband cable to WAN port of Router 1 and can connect to the internet. I connected the LAN port 1 from Router 1 via Ethernet cable to Router 2's WAN port. Unfortunately router 2 does not connect to the internet.
What am I doing wrong?
Router 1 has an IP address of 192.168.1.1 and Router 2 is 192.168.2.1 so there should be no clash?
On Router 1 I connect using PPPOE. On Router 2 I also try to connect to PPPOE but there is no connection to the internet. I can't work out why.
What I did:
