Question Setting up the TV/Raspberry Pi sound chain
gordonfreemanjr
54
So I need to set the sound chain around my TV properly - and it’s a tricky one:
I want to run music and games from my RASPBERRY PI 4, connected to a USB SOUND CARD. The main audio out is the SOUNDBAR attached to the TV.
The TV is being used basically as a monitor, there’s no cable and I want to keep it this way. I need it as a video out for my Pi 4 and as a movie player (from a USB drive).
The problem is, if I connect a USB drive directly to the TV to watch a movie, I’m bypassing the USB sound card, which is attached to a Pi 4 earlier in the chain. How to make it work? Can I use a USB sound card as both main audio outputs for the Pi 4 and TV?
Please keep in mind that I still want the sound to reach me via the soundbar. So:
Raspberry Pi4/USB Sound Card > TV > Soundbar
or:
  1. Raspberry Pi4/USB Sound Card > TV > Soundbar
  2. USB drive > TV > USB Sound Card > Soundbar
or, I don’t know, maybe bypass the TV soundwise and attach the sound card straight to the soundbar, placing it fuhrer down within the chain?
Help!
I just figured that RPi is going to sound terribly on it’s own, and the soundbar as an audio out is only going to amplify the effect. You’re saying that a sound card is not needed in this setup?
HDMI already puts out audio info but is in digital form, so ur soundbar needs to have HDMI IN/OUT to take advantage of this feature, otherwise you are stuck with the un-ideal USB sound dongle.
Well, the soundbar has an HDMI in. The problem is that the TV has no HDMI out. And I need to include the TV within the chain as a monitor.
