I am a first timer building a new PC. I had a bit of trouble getting an install of Windows without BSOD errors. My first install of Windows 10 worked pretty flawlessly, until I had trouble with my graphics card driver, leading me to doing a fresh install. Since then I've been receiving BSOD errors consistently on my PC and I cannot pin point the issue. I believe it could be a corruption problem with my SSD after running Active Partition Recovery and it showing several overlapped sectors.
My Build:
CPU: i5-6600k
Motherboard: ASUS z170-A
RAM: G.skill Ripjaw V Series 16gb (2x8gb)
SSD: Kingston Savage 250GB
HHD: Western Blue 1TB Internal Drive
Graphics Card: MSI Radeon Rx480 8gb
On Sat 2/11/2017 11:44:32 PM your computer crashed
crash dump file: C:\Windows\Minidump\021117-5359-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1F5C0C)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000005, 0xFFFFF8015BE79C0C, 0xFFFF80013023A0A8, 0xFFFF8001302398D0)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: ntkrnlmp.exe (nt!KeBugCheckEx+0x0)
Bugcheck code: 0x7E (0xFFFFFFFFC0000005, 0xFFFFF8015BE79C0C, 0xFFFF80013023A0A8, 0xFFFF8001302398D0)
Bug check description: This bug check indicates that a system thread generated an exception that the error handler did not catch.
On Sat 2/11/2017 11:37:18 PM your computer crashed
crash dump file: C:\Windows\Minidump\021117-5578-01.dmp
This was probably caused by the following module: ntfs.sys (NTFS+0x1F281)
Bugcheck code: 0xBE (0xFFFF8B80464779E0, 0x8000000001000121, 0xFFFFA6017E578A30, 0xB)
Error: ATTEMPTED_WRITE_TO_READONLY_MEMORY
file path: C:\Windows\system32\drivers\ntfs.sys
description: NT File System Driver
Bug check description: This is issued if a driver attempts to write to a read-only memory segment.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
On Sat 2/11/2017 11:17:34 PM your computer crashed
crash dump file: C:\Windows\Minidump\021117-5875-01.dmp
This was probably caused by the following module: npfs.sys (0xFFFFF809224CB391)
Bugcheck code: 0x50 (0xFFFFFFFFFFFFFF8B, 0x2, 0xFFFFF809224CB391, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\drivers\npfs.sys
description: NPFS Driver
Bug check description: This indicates that invalid system memory has been referenced.
On Sat 2/11/2017 7:42:47 PM your computer crashed
crash dump file: C:\Windows\Minidump\021117-5171-01.dmp
This was probably caused by the following module: fastfat.sys (fastfat+0x43DF)
Bugcheck code: 0x23 (0xE0121, 0xFFFFAE000F5655F8, 0xFFFFAE000F564E20, 0xFFFFF80BAC5CEC81)
Error: FAT_FILE_SYSTEM
file path: C:\Windows\system32\drivers\fastfat.sys
description: Fast FAT File System Driver
Bug check description: This indicates that a problem occurred in the FAT file system.
Google query: Microsoft Corporation FAT_FILE_SYSTEM
I have attached first a copy of the DMP files and the error codes I received and then also the disk analysis done by Active Partition Recovery. I'm looking for any type of direction thank you!
Here is a link to my Minidump files for the BSODs: https://www.dropbox.com/sh/4qab4utr4285ii0/AACF79Tug7UjQZLazMvD6RIha?dl=0
Once again I am very grateful to anyone who can help me find a solution, I am desperate at this point!
Thank you,
Inexperienced Builder
My Build:
CPU: i5-6600k
Thank you,
