Sfc SCANNOW can't fix problems.
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I think the title explains everything.
Here's the log.
If you need more info tell me and I will reply ASAP.
Its the log that windows gave me after the scan. Do you want me to upload somewhere else maybe?
As you can see in the picture there are corrupted files.
I don't have any specific problem but I figured I would do this command just to make sure everythings fine after the system restore you instructed me to do previously. Near the end of the log it says that there are 5 problems not fixed i think. If it helps you I can post the full log here or part of it.
In all the times I've run the SFC command.. it's NEVER... ever.. actually fixed any of my problems. It doesn't work too well with OEM versions of Windows because it will say insert the Windows DVD midway through and OEM versions of Windows are different and it won't recognize it... and other times I've tried it.. it simply told me it was unable to fix the problem.
If your system has serious issues... rather than spending days/weeks trying to find a solution... just backup your data and do a new/clean/fresh reinstall of Windows... that will take 15 min. tops..(plus 2 days for the updates).
Thanks everyone, I will try your suggestions tomorrow because it's really late here and I've got important exams tomorrow... Look forward to my answer...
2015-06-03 03:26:34, Info CSI 000008f8 [SR] Verify complete
2015-06-03 03:26:34, Info CSI 000008f9 [SR] Repairing 5 components
2015-06-03 03:26:34, Info CSI 000008fa [SR] Beginning Verify and Repair transaction
2015-06-03 03:26:34, Info CSI 000008fb Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\utc.app.json do not match actual file [l:24{12}]"utc.app.json" :
Found: {l:32 b😀k6fUP1SnCTleFraPRQVF4X7qKh8b/NoJA44WgQ6+JE=} Expected: {l:32 b:6510UErwHGoFg3sRd3gzh3HSbTceuHem3Rnk0NraKS8=}
2015-06-03 03:26:34, Info CSI 000008fc [SR] Cannot repair member file [l:24{12}]"utc.app.json" of Microsoft-Windows-Unified-Telemetry-Client, Version = 6.3.9600.17747, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-06-03 03:26:34, Info CSI 000008fd Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\telemetry.ASM-WindowsDefault.json do not match actual file [l:66{33}]"telemetry.ASM-WindowsDefault.json" :
Found: {l:32 b:iOgJ9zpM/uQDvt0owjVftLgMNGL/hKwbMjRM5vyAQDk=} Expected: {l:32 b:EeQJzlVPvq9GNIcA2FEwrOjEeuDam1G+ol3x61gKasQ=}
2015-06-03 03:26:34, Info CSI 000008fe [SR] Cannot repair member file [l:66{33}]"telemetry.ASM-WindowsDefault.json" of Microsoft-Windows-Unified-Telemetry-Client, Version = 6.3.9600.17747, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-06-03 03:26:34, Info CSI 000008ff Hashes for file member \SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB do not match actual file [l:36{18}]"Amd64\CNBJ2530.DPB" :
Found: {l:32 b:wnqsJ3Yrml1LGNq4+bZ8i2lz5e4oQNkulQrfWYilA1k=} Expected: {l:32 b:n520k714Uu3utHa5JGQ6HQYbZphKhlMWq5pEmfnCDuw=}
2015-06-03 03:26:34, Info CSI 00000900 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-06-03 03:26:34, Info CSI 00000901 [SR] Repairing corrupted file [ml:520{260},l:82{41}]"\??\C:\Windows\System32\driverstore\en-US"\[l:34{17}]"wvms_vspp.inf_loc" from store
2015-06-03 03:26:34, Info CSI 00000902 [SR] Repairing corrupted file [ml:520{260},l:74{37}]"\??\C:\Windows\System32\drivers\en-US"\[l:32{16}]"vmswitch.sys.mui" from store
2015-06-03 03:26:34, Info CSI 00000903 [SR] Repairing corrupted file [ml:520{260},l:82{41}]"\??\C:\Windows\System32\driverstore\en-US"\[l:30{15}]"wvms_pp.inf_loc" from store
2015-06-03 03:26:35, Info CSI 00000904 Hashes for file member \SystemRoot\WinSxS\amd64_prncacla.inf_31bf3856ad364e35_6.3.9600.17415_none_95dd5540d57f8c01\Amd64\CNBJ2530.DPB do not match actual file [l:36{18}]"Amd64\CNBJ2530.DPB" :
2015-06-03 03:26:35, Info CSI 00000905 [SR] Cannot repair member file [l:36{18}]"Amd64\CNBJ2530.DPB" of prncacla.inf, Version = 6.3.9600.17415, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type = [l:24{12}]"driverUpdate", TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-06-03 03:26:35, Info CSI 00000906 [SR] This component was referenced by [l:166{83}]"Package_2709_for_KB3000850~31bf3856ad364e35~amd64~~6.3.1.8.3000850-6825_neutral_GDR"
2015-06-03 03:26:35, Info CSI 00000907 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\utc.app.json do not match actual file [l:24{12}]"utc.app.json" :
2015-06-03 03:26:35, Info CSI 00000908 [SR] Cannot repair member file [l:24{12}]"utc.app.json" of Microsoft-Windows-Unified-Telemetry-Client, Version = 6.3.9600.17747, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-06-03 03:26:35, Info CSI 00000909 [SR] This component was referenced by [l:154{77}]"Package_2_for_KB3022345~31bf3856ad364e35~amd64~~6.3.1.5.3022345-2_neutral_GDR"
2015-06-03 03:26:35, Info CSI 0000090a Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\telemetry.ASM-WindowsDefault.json do not match actual file [l:66{33}]"telemetry.ASM-WindowsDefault.json" :
2015-06-03 03:26:35, Info CSI 0000090b [SR] Cannot repair member file [l:66{33}]"telemetry.ASM-WindowsDefault.json" of Microsoft-Windows-Unified-Telemetry-Client, Version = 6.3.9600.17747, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, hash mismatch
2015-06-03 03:26:35, Info CSI 0000090c [SR] This component was referenced by [l:154{77}]"Package_2_for_KB3022345~31bf3856ad364e35~amd64~~6.3.1.5.3022345-2_neutral_GDR"
2015-06-03 03:26:35, Info CSI 0000090d Hashes for file member \??\C:\ProgramData\Microsoft\Diagnosis\DownloadedSettings\utc.app.json do not match actual file [l:24{12}]"utc.app.json" :
2015-06-03 03:26:35, Info CSI 0000090e Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\utc.app.json do not match actual file [l:24{12}]"utc.app.json" :
2015-06-03 03:26:35, Info CSI 0000090f [SR] Could not reproject corrupted file [ml:520{260},l:114{57}]"\??\C:\ProgramData\Microsoft\Diagnosis\DownloadedSettings"\[l:24{12}]"utc.app.json"; source file in store is also corrupted
2015-06-03 03:26:35, Info CSI 00000910 Hashes for file member \??\C:\ProgramData\Microsoft\Diagnosis\DownloadedSettings\telemetry.ASM-WindowsDefault.json do not match actual file [l:66{33}]"telemetry.ASM-WindowsDefault.json" :
2015-06-03 03:26:35, Info CSI 00000911 Hashes for file member \SystemRoot\WinSxS\amd64_microsoft-windows-u..ed-telemetry-client_31bf3856ad364e35_6.3.9600.17747_none_90df8130dac08ee0\telemetry.ASM-WindowsDefault.json do not match actual file [l:66{33}]"telemetry.ASM-WindowsDefault.json" :
2015-06-03 03:26:35, Info CSI 00000912 [SR] Could not reproject corrupted file [ml:520{260},l:114{57}]"\??\C:\ProgramData\Microsoft\Diagnosis\DownloadedSettings"\[l:66{33}]"telemetry.ASM-WindowsDefault.json"; source file in store is also corrupted
2015-06-03 03:26:35, Info CSI 00000913 Ignoring duplicate ownership for directory [l:92{46}]"\??\C:\ProgramData\Microsoft\Diagnosis\ETLLogs" in component Microsoft-Windows-Unified-Telemetry-Client, Version = 6.3.9600.17747, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2015-06-03 03:26:35, Info CSI 00000914 [SR] Repairing corrupted file [ml:520{260},l:82{41}]"\??\C:\Windows\System32\driverstore\en-US"\[l:30{15}]"wvms_mp.inf_loc" from store
2015-06-03 03:26:35, Info CSI 00000915 [SR] Repair complete
2015-06-03 03:26:35, Info CSI 00000916 [SR] Committing transaction
2015-06-03 03:26:35, Info CSI 00000917 Creating NT transaction (seq 2), objectname [6]"(null)"
2015-06-03 03:26:35, Info CSI 00000918 Created NT transaction (seq 2) result 0x00000000, handle @0x4b0
2015-06-03 03:26:35, Info CSI 00000919@2015/6/3:00:26:35.396 Beginning NT transaction commit...
2015-06-03 03:26:35, Info CSI 0000091a@2015/6/3:00:26:35.630 CSI perf trace:
I know its more than 20 lines but I wanted to make sure it has everything you need...
