Question Shook my pc weird sound
Dec 24, 2018
22
So i shook my pc and there was a noise like somthing was shaking inside but nothing was moving is that normal or is it an issue when i shook it it sounded like it was coming from the top area of my pc and sometimes it sounded lower and sometimes it was both
You left out some details. If it's a laptop, its probably a loose screw or debris. If it's a desktop it could be as simple as wires bumping the case. But you can hear the difference. Also shaking a computer can definitely strain components such as the motherboard and gpu connections.
Its a desktop ive taken both hdd and ssd out and looked as i shook it and could not see wires hitting the case i have the inwin 101 case idk if thatll help you idk if its a matter of positioning sometimes when i move it forward the noise stops and sometimes it doesn’t also apart from unused wires that were tucked in an open space my wires are zip-tied to the case
