Shortcut problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.customize (More info?)
Hello,
I have my XP Professional set up so that in Windows Explorer
everything opens in folder view. But when I put a shortcut to a file
on the desktop and click on it, it doesn't open in folder view. Is
there a way to correct this?
Thank you.
Norman Stein
Norman,
Where is the shortcut pointing to and what are the parameters assigned?
Explorer.exe Command-Line Options for Windows XP
http://support.microsoft.com/default.aspx?scid=314853
Customize the Windows Explorer Views in Windows XP
Open folders in Windows Explorer mode by default (i.e. with folder pane
enabled):
http://www.winxptutor.com/folderpane.htm
Ramesh, Microsoft MVP
Window XP Shell/User
http://www.mvps.org/sramesh2k
"Norman Stein" <normannospam.stein@wanadoo.fr> wrote in message
news:vku6i0tc8f26u6j6h7vnbihdg3putrdofr@4ax.com...
Hello,
Thank you.
Norman Stein
Ramesh,
Thank you very much. The final reference was exactly what I needed.
Norman
On Thu, 19 Aug 2004 08:56:53 +0530, "Ramesh [MVP]"
<ramesh@nojunkmails.com@mvps.org> wrote:
>Norman,
>enabled):
You're welcome Norman.
news:e19ei0pibt43uent797m23viqgi6u3jko8@4ax.com...
Ramesh,
Norman
>Norman,
>enabled):
