Should I be using an AIO cooler for overclocking?
scandrews
84
6
18,535
I have a Ryzen 1300x, overclocked to 3.975 at 1.325v. Right now I am using the stock cooler, but I have a CoolerMaster 120 lite AIO.
Should I use that for overclocking, or stay with the stock?
I would ask you to limit ur oc to 1.35v if you want a long life for ur cpu. Going beyond 3.9ghz for a 60hz monitor, the gains are not worth it. And yes, I expect the AIO to give you about 5 c cooler avg Temps at 50% fan load.
First off thats a good OC for that CPU and voltage! Your cooler seems fine unless your concerned about your temps under load. I would rather use a liquid cooled unit vs. an air cooled unit any day of the week, especially if your overclocked. If your not suffering from any crashes or concerned about temperatures I think you are good.
My temps are running around 45-47 c. I've got 2 intake fans and 3 blowing exhaust.
Should I raise the voltage? This is my first build, and I don't want to fry the CPU or MB, and then have to ask my dad to buy another for me.
